Tamiya 49xxx Limited Edition Parts
:fl: les pièces options, les pneus...
MAKi
Messagepar MAKi » lun. 1 sept. 2008 09:35
49001 2WD Front Tyre (Red)
49002 2WD Front Tyre (Yellow)
49003 2WD Front Tyre (White)
49004 Oval Block Tyre Front (Red)
49005 Oval Block Tyre Front (Yellow)
49006 Oval Block Tyre Front (White)
49007 Oval Block Tyre Rear (Red)
49008 Oval Block Tyre Rear (Yellow)
49009 Oval Block Tyre Rear (White)
49010 Pin Spike Tyre Front (Red)
49011 Pin Spike Tyre Front (Red)
49012 Pin Spike Tyre Front (Yellow)
49013 Pin Spike Tyre Front (White)
49014 Pin Spike Tyre Rear (Red)
49015 Pin Spike Tyre Rear (Yellow)
49016 Pin Spike Tyre Rear (White)
49017 2WD Wheel Set Front and Rear (White)
49018 2WD Wheel Set Front and Rear (Silver)
49019 4WD Wheel Set Front and Rear (White)
49020 4WD Wheel Set Front and Rear (Silver)
49021 2WD FRONT Day Glow Wheel Set (Red)
49022 2WD FRONT Day Glow Wheel Set (Yellow)
49023 2WD Front Day-Glow Wheel Set (Green)
49024 2WD Rear Day-Glow Wheel Set (Red)
49025 2WD Rear Day-Glow Wheel Set (Yellow)
49026 2WD Rear Day-Glow Wheel Set (Green)
49027 1 Piece Racing Spoke Wheel (Gold plated)
49028 1 Piece Racing Spoke Wheel (Silver plated)
49029 1 Piece Racing Spoke Wheel (Blue plated)
49030 RC Parts Case
49031 RCC Wing Duct Set
49032 M Chassis 60D Super Grip White Wall Tyre
49033 Flexible Sticker (Carbon)
49034 Flexible Sticker (Smoke)
49035 Flexible Sticker (Transparent)
49036 Fluorescent High Torque Servo Saver (Orange)
49037 Low Friction Aluminum Damper (Blue 1 Pair)
49038 One Piece 5 Spoke Wheel Black 1 Pair
49039 M-Chassis Heat Sink (Blue)
49040 Mini Cooper Wheels Yellow
49041 Mini Cooper Wheels Red
49042 Mini Cooper Wheel Set Blue
49043 Mini Cooper Wheels (White, 1 Pair)
49044 M-Chassis A Parts (Moss Green)
49045 M-Chassis B Parts (Moss Green)
49046 5mm Adjuster Red
49047 M Chassis Number Sticker Mini Cooper
49048 Nylon Band with Metal Hook (Blue)
49049 Nylon Band with Metal Hook (Yellow)
49050 Nylon Band with Metal Hook (Green)
49051 Nylon Band with Metal Hook (Orange)
49052 Nylon Band with Metal Hook (Dark Red)
49053 2ch 1ESC 1 Servo (Wheel Control) Radio Set
49054 2ch 1ESC 2 Servo (Stick)Radio Set
49055 2ch 2 Servo (Yacht-Use) Radio Set
49056 4ch 1ESC 2 Servo Radio Set
49057 Stainless Snap Pin (Large)
49058 Stainless Snap Pin (Small)
49059 No. 900 Damper Oil (9cc)
49060 Colour Antenna Pipe (Red)
49061 Colour Antenna Pipe (Blue)
49062 Colour Antenna Pipe (Black)
49063 Colour Antenna Pipe (Purple)
49064 RC Yacht Use 2Ch 2 Servo Radio Set
49065 1/8 Engine RC Car-Use 2ch 2 Servo Radio Set
49066 C.V.A Damper Mini (II) White
49067 Aluminium King Pins (Red)
49068 Aluminium King Pins (Blue)
49069 TA03 Super Low Friction Damper (Blue)
49070 TA03 Super Low Friction Damper (Purple)
49071 5mm Alu. Ball Connector (Red)
49072 5mm Alu. Ball Connector (Blue)
49073 TA03 Aluminum Pulley (Blue, 16T)
49074 TA03 Aluminum Pulley (Red, 16T)
49075 Carbon Reinforced 1-piece 5-spoke Wheel
49076 Tamiya Lancia Rally Body Parts Set (Re-Issue)
49077 Porsche Boxster Front Carbon-Reinforced Wheel
49078 Porsche Boxster Rear Carbon-Reinforced Wheel
49079 CVA Mini Shock II - Transparent
49080 Not Used
49081 Not Used
49082 Rover Mini Cooper Complete Kit
49083 Fiat Abarth 1000TCR Berlina Corsa Complete Kit
49084 Honda S-MX Lowdown Complete Kit
49085 Porsche Boxster Complete Kit - M02L
49086 Mercedes-Benz SLK Complete Kit
49087 CVA Mini Shock Unit II - Transparent
49088 CVA Super Mini Shock Unit Set Transparent
49089 TA03 Super Low Friction Damper - Metallic Black
49090 5mm Aluminum Ball Connector - Purple
49091 TA03 Lightweight Drive Shaft Purple
49092 Aluminum Servo Stay Blue
49093 Aluminum Servo Stay Purple
49094 4mm Alum Flange Lock Nuts - Red/Blue (2pcs each)
49095 Countach LP500S Re-issue 1/10 Body Parts Set (White).
49096 Aluminum Servo Stay - Pink
49097 TA03 Alum Front Hub Carrier - Blue
49098 TA03 Universal Drive Shaft - Pink
49099 TA03 Low Friction Damper - Silver/Blue
49100 TA03 Low Friction Damper - Silver/Pink
49101 Aluminum King Pins Pink
49102 Aramid Fiber Drive Belt - TA03F/R Blue
49103 TA03FS & RS Reinforced Drive Belt Red
49104 Glass Tape Blue
49105 Glass Tape Red
49106 Glass Tape Black
49107 Antenna Pipe (black)
49108 TA03 Carbon Reinforcing Plate - Blue
49109 TA03 Carbon Reinforcing Plate Black
49110 TA03 A Parts (Gear Case) - Black
49111 TA03 B Parts (Rr Gear Case) - Black
49112 TA03 D Parts (Sus Arm) - Black
49113 1/12 Celica LB Turbo GR.5 Body Set
49114 Damper oil #900 2 set
49115 TA03 Pully Stopper
49116 Piston Set for 53280?????
49117 Clear Silicon Damper Seals (???)
49118 Reynard 97D Prepainted white
49119 RC Tyre Carrying Case
49120 Lightweight Aluminum Wheel Hub
49121 TA03 Stabilizer Stopper Set
49122 Damper Air Remover
49123 Damper Tune-up Set
49124 Mobil 1NSX Lightweight Body Set
49125 Mercedes CLK Lightweight Body Set
49126 Porsche 911 GT1 Lwt Body Set
49127 TRF Original Sticker
49128 AO-5005 King Tiger DMD Turret Traversing Unit
49129 Johnson Motor
49130 Stealth Box
49131 AO-5006 Low Friction Use O Ring & Spacer Set
49132 TRF414 Chassis Kit
49133 Mini Cooper Monte Carlo Completed Product [for export]
49134 RCC Porche 911 Carrera Completed Product (Silver) [for export]
49135 RCC Porche 911 Carrera Completed Product (Blue) [for export]
49136 RCC Porche 911 Carrera Completed Product (Yellow) [for export]
49137 RCC Porche 911 Carrera Completed Product (Red) [for export]
49138 Tyrrell P34 Six Wheelser Body Parts Set
49139 TA03R-S TRF Special Chassis Kit w/Lightweight Body
49140 Aluminum Setting Wheel
49141 Super Low Friction Damper II
49142 Lt Wgt Alum Wheel Hub - Thick
49143 Damper Air Remover (Smoke)
49144 Camber Gauge
49145 Impreza WRC Body - Painted
49146 Calsonic Skyline GT-R (R34) Lightweight Body Parts Set
49147 Bag
49148 Subaru Impreza WRC (Fully Assembled w/RC Unit) - TGX
49149 TGX-Mk.1 SUBARU IMPREZA WRC Complete Kit
49150 AO-5008 TG10 SLK White Wheel
49151 Toyota bB Completed Product White
49152 Honda City Turbo Spare Body
49153 Toyota bB Completed Product Black
49154 Tyrrell P34 Six Wheeler Kit
49155 NiMH (Nickel metal hydride) Battery 3000MH
49156 3x8 Round Hex Head Screw
49157 3x10 Round Hex Head Screw
49158 3x12 Round Hex Head Screw
49159 3x14 Round Hex Head Screw
49160 3x8 Countersunk Hex Screw
49161 3x10 Countersunk Hex Screw
49162 3x16 Countersunk Hex Screw
49163 Countersunk Washer for Hex Screw
49164 Hex Wrench Driver - 1.5, 2mm
49165 Screw Case
49166 Juggernaut 2 Frame Blue
49167 Juggernaut 2 Anodized Chassis Frame Set (Red)
49168 Juggernaut 2 Bumper Blue
49169 Juggernaut 2 Bumper Red
49170 Esso Ultron Tiger Supra Kit - TGX
49171 7.2V Racing Pack 1700MP Battery
49172 TG10 Mk.1 PRO Racing - Long Suspension w/Body Kit
49173 TRF414M Custom Pack M
49174 Mad Bull Special Complete Kit
49175 TRF414M Chassis Kit
49176 Subaru WRC 2001- TG10
49177 Ferrari 312T3 Body Parts Set
49178 Locktite GT-R (R34) Lightweight Body Set
49179 Body Set Ferrari Modena - Light Weight Body Set
49180 GP Body Set CLK DTM 2000 - Original Teile Finished Body
49181 Unimog U300 Complete Kit (Orange)
49182 Unimog U300 Complete Kit (Green)
49183 Med.Narrow Dish Wheels - Flou.Yellow (Offset 0)
49184 Not Used
49185 Harbour Boat
49186 Unimog Hunter
49187 F1 Body Parts Set
49188 Body Set Corvette C5-R - Finished Body (blue)
49189 AO-5009 Nissan 300ZX IMSA GTS Spare Body
49190 Dyna Storm (Re-Release
49191 Ferrari 312T3 - F103RS
49192 Bus
49193 M4 Sheman & Photo Collection
49194 TA04 Aluminum Steering Post Blue
49195 TA04 Alum Steering Arms - Blue
49196 Short Alum Servo Stays - Blue
49197 4mm Turnbuckle Wrench - Blue
49198 TRF Damper Set - Blue 4pcs
49199 TA04 Alum Motor Heat Sink - Blue
49200 TA04 Universal Shaft Set
49201 TA04 Rear Universal Shaft Set - Lightweight Assembly
49202 TA04 Aluminium Hub Set for Spur Gear Blue
49203 TA04 Reinforced Gear Case
49204 Dish Wheel (+0, Blue)
49205 Dish Wheel (+0, Magenta)
49206 Body Set HKS Racing Altezza
49207 TA04 PRO Blue Collection
49208 Body Set HKS Racing Altezza - Carbon
49209 Tiger I Early Production Photo Etched Grille Set
49210 AO-5010 6-Spoke Wheel White (Offset+2) Set of four
49211 1 / 12 Smart Cabrio (Red)
49212 1 / 12 Smart Cabrio (Blue)
49213 1 / 12 New Mini Cooper (Yellow)
49214 1 / 12 New Mini Cooper (Blue)
49215 Power Loader
49216 Power Shovel
49217 1 / 12 Smart Cabrio (Grey)
49218 1 / 12 New Mini Cooper (Green)
49219 TRF414M2 Chassis
49220 TRF414M Champion Memorial Chassis Kit
49221 Lamborghini Contach LP500S Body (Black)
49222 Lotus 79 Body Parts Set (Re-Release)
49223 Ferrari F40 GT Body (200mm) Body Parts Set
49224 Car Maintenance Stand - Blue
49225 Camber Gauge - Black
49226 Height Gauge (Blue)
49227 Wheel Wrench - Blue
49228 Pinion Gear Holder (Blue)
49229 TRF Sticker B - Blue/Yellow
49230 Hard Coated 0.6 Alumium Pinion Gear (27T/TA-04)
49231 Hard Coated 0.6 Alumium Pinion Gear (22T/TB-01)
49232 0.6 Alum Pinion Gear - Hard Coated (19T/TL-01)
49233 Hard Coated 0.4 Aluminum Pinion 39T/TA04
49234 Hard Coated 0.4 Alumium Pinion Gear (35T/TB-01)
49235 Hard 0.6 Spur Gear (83T/TA04)
49236 0.6 Hard Spur Gear - (55T/TB-01, F201)
49237 0.4 Hard Spur Gear - (120T/TA04)
49238 Hard 0.4 Spur Gear (88T) TB01
49239 TRF Sticker B Gold/Silver
49241 Matched Spring Set - Medium 4pcs
49242 Matched Spring Set - Hard 4pcs
49243 Aluminum Stabilizer End Blue 4pc
49244 5mm Alum Ball Nuts - Blue 10pcs
49245 TRF Special Damper Retainer - Blue 4pcs
49246 TRF Sticker B - Blue/Pink
49247 Super Stock Motor Type S
49248 Pit Bag w/3 Box (Navy Blue)
49249 TB Evolution II Suspension Setting Parts
49250 Datsun 280ZX Body Parts Set (Reissue)
49251 Mercedes Trailer Truck (Red)
49252 1/12 Audi TT Roadster (Silver)
49253 1/12 Porsche 911 Turbo (Yellow)
49254 TRF 2002 ESC
49255 TRF414M World Champion Replica Chassis Kit
49256 Mercedes Benz C11 Spare Body
49257 Idemitsu Motion Mugen Civic Spare Body
49258 TRF414 Front Stabilizer - World Champion Replica
49259 Tire Warmer
49260 Super Stock Motor Type RR
49261 1 / 12 Mercedes-Benz SL500 (Silver)
49262 1 / 12 Mercedes-Benz SL500 (Black)
49263 Body Set 360 Modena - Ltd Carbon
49264 Body Set Skyline R34 - Ltd Carbon
49265 Body Set Toyota MR-S - Ltd Lightweight
49266 TRF Setting Board - Ltd
49267 TRF Tool Set - Ltd
49268 7.2v Racing Pack RC2400SP Zapped Type
49269 TRF414M Lightweight Front Bulkhead
49270 TRF414M Lightweight Rear Bulkhead
49271 TRF414M Lightweight Motor Plate
49272 TRF414M SSG Carbon Upper Deck
49273 TRF414M SSG Carbon Lower Deck - Ltd
49274 TRF414M SSG Carbon Front Damper Stay
49275 TRF414M SSG Carbon Rr Damper - Ltd
49276 Body Set Raybrig NSX 2002 - Ltd Lightweight
49277 Body Set Nissan 350Z - Ltd Carbon Pattern
49278 TA04 TRF - Ltd
49279 Body Set Raybrig NSX 2002 - Ltd Carbon Pattern
49280 Body Set Toyota MR-S - Ltd Carbon Pattern
49281 1/10 Ferrari 312T3 Tyre R
49282 1/10 Ferrari 312T3 Plated Wheel
49283 TB-Evo.3 Surikarn Ltd. - Ltd
49284 Nissan R91CP Spare Body
49285 Jaguar XJR-12 Spare Body
49286 Skyline GT-R (R32) Carbon Print Body
49287 Sport Tuned Mortor for XB Cars
49288 Super Stock Motor Type RR (Gun Metal Case)
49289 Enzo Ferrari Carbon Print Body
49290 Setting Board (Red)
49291 Maintenance Stand (Red)
49292 TRF Tool Set (Red)
49293 TRF Damper Set - Fluorine Coated Blue
49294 TRF Damper Set - Fluorine Coated Red
49295 Toyota Celica GT-FOUR RC Body
49296 Subaru Brat Body
49297 TA04R Tuned Chassis Kit - Ltd
49298 RD F-1 Spoke Wheel Set 3630F/3645R (Black)
49299 Ball Diff Spring
49300 620 Ball Thrust Bearing (2pcs).
49301 Fiat Abarth Corsa Body Parts
49302 Matched Springs (Soft 2 Pieces)
49503 Matched Springs (Medium 2 pieces)
49304 Matched Springs (Hard 2 pieces)
49305 Matched Springs (Extra Hard 2 pieces)
49306 TRF Sticker B (Red Tone)
49307 TRF Sticker B (Blue Tone)
49308 TRF Damper Aluminum Top End (Blue)
49309 TRF Damper Cylinder Cap Set Blue
49310 TRF Damper Cylinder Nut (Blue)
49311 TRF Damper Aluminum Retainer (Blue)
49312 TRF Damper Alum Top End - Red
49313 TRF Damper Cylinder Cap - Red
49314 TRF Damper Cylinder Nut - Red
49315 TRF Damper Alum Retainer - Red
49316 3x18mm Aluminum Turnbuckle Shafts Blue
49317 3x23mm Aluminum Turnbuckle Shafts Blue
49318 3x32mm Aluminum Turnbuckle Shafts Blue
49319 3x35mm Aluminum Turnbuckle Shafts Blue
49320 LW Alum Servo Stay - Blue
49321 5mm Aluminum End Cap for Body Mount Blue
49322 6mm Aluminum End Cap for Body Mount Blue
49323 3x18mm Aluminum Turnbuckle Shafts Red
49324 Alum Turnbuckle Shafts - 3x23mm Red 2pcs
49325 Alum Turnbuckle Shafts - 3x32mm Red 2pcs
49326 3x35mm Aluminum Turnbuckle Shafts Red
49327 LW Alum Servo Stay - Red
49328 5mm Alum End Cap - Red For Body Mount
49329 6mm Aluminum End Cap for Body Mount Red
49330 1 / 12 Mercedes-Benz ML55 AMG (Red)
49331 1 / 12 Mercedes-Benz ML55 AMG (Silver)
49332 1 / 12 BMW Z8 (Red)
49333 1 / 12 BMW Z8 (Yellow)
49334 1 / 12 Opel Speedster (Silver)
49335 TB Evo III Conversion Parts - Blue
49336 F201 Tuned Chassis Kit - F201
49337 Wild Willy 2 - Metallic Special
49338 Alpine A110 Spare Body
49339 Body Set Raybrig NSX 2003 - Lightweight
49340 Body Set Xanavi Nismo GT-R - Lightweight
49341 TRF415 Lower Deck - for Stick Type Battery
49342 TRF415 Motor Mount Bulkhead Heat Sink Type
49343 TRF415 Belt Stabilizer
49344 TRF415 Heat Sink Beam
49345 TB Evo IV Titanium Screws
49346 TRF415 LW Suspension Set - Reversible
49347 Transpeed MS Motor 9T
49348 TB-02R Chassis Kit
49349 TRF415MS Chassis Kit LE - Limited Edition
49350 2x25mm Cap Screw - w/2mm Lock Nut
49351 TRF415MS World Champ Parts
49352 Impreza WRC 2004 - TL01RA
49353 TB Evolution IV MS - TBEVOIV
49354 Tamiya Pit Case - Blue
49355 TRF Damper Special Blue
49356 TB Evolution IV Aluminum Center Post
49357 TB Evolution IV Seperate Motor Mount MS
49358 TRF415 Front Direct Coupling (Spool)
49359 TB Evo IV Front Direct Coupling (Spool)
49360 TA05 Titanium Screw Set
49361 6-Spoke Setting Wheels (Blue)
49362 TB Evo IV Gear Cover - Smoke 2pcs
49363 TB Evo IV Gear Cover - Clear Blue 2pcs
49364 TB-02R Front Carbon Brace Set
49365 TB-02R Rear Carbon Brace Set
49366 TB02R Battery Plate
49367 TB-02 Aluminum Racing Steering Set (Blue)
49368 TB-02 Aluminum Motor Mount (Blue)
49369 TB-02R LW Alu Propeller Shaft Blue TB02
49370 F201 Aluminum Racing Steering
49371 F201 7mm Ball Connector - 2pcs Titanium
49372 TB Evo IV Gear Cover - Red 2pcs ?????
49373 TNX Pro-Line Special
49374 Body Set Subaru Legacy B4 - Lightweight
49375 Body Set Xanavi NISMO Z - Lightweight
49376 Body Set Raybrig NSX 2004 - Lightweight
49377 TA03F Pro Drift Spec Chassis Kit
49378 TRF415MSX Up-Grade Parts
49379 Antenna Pipes Fluor. Blue
49380 7mm Snap Pin Blue 5pc
49381 TRF415MSX
49382 On Road Tuned Hard Spring Set White
49383 TA05 Stabilizer Set F/R Black
49384 TRF415MSX Screw Set Titanium & Aluminum
49385 TRF415MSX Lower Deck - for Stick Type Battery
49386 Transpeed MS Motor 10T
49387 Porsche 911 GT2 Body Parts Set
49388 TA05 Carbon Reinforced Damper Stay
49389 On Road Tuned Hard Spring Set Milky Blue
49390 TA05 Bulkhead Clear Blue
49391 TA05 Upper Brace F R (Clear Blue)
49392 TB Evolution 5 Stabilizer Rod Set
49393 TB Evolution 5 Screw Set (Titanium & Aluminum).
49394 TRF415MSX Marc Rheinard Ed.
49395 TB Evolution 5 Stabilizer Rod Set Black
49396 TB Evolution 5 Gear Cover Clear Blue
49397 TB Evolution 5 Gear Cover Clear Smoke
49398 TB Evolution 5 Bumper Clear Blue
49399 TB Evolution 5 Bumper Clear Smoke
49400 Porsche Turbo RSR Type 934 - TA05
49401 TRF501X
49402 MN 6-Spoke Wheel Clear - +2
49403 Medium Narrow 6 Spoke Wheels Clear Blue
49404 MN 6-Spoke Wheel Smoke - +2
49405 Medium Narrow Dish Wheels Clear Offset O
49406 MN Dish Wheel Clear Blue - +/-0
49407 MN Dish Wheel Smoke - +/-0
49408 MN Mesh Wheel Clear - +2
49409 Medium Narrow Mesh Wheels Blue Offset +2
49410 Medium Narrow Mesh Wheels Smoke Offset +2
49411 MN 18-Spoke Clear - +/-0
49412 MN 18-Spoke Clear Blue - +/-0
49413 MN 18-Spoke Smoke - +/-0
49414 TA05 Stabilizer Set F/R Milky Blue
49415 Body Set Mobil 1 SC430 LW
49416 Carbon Bumper Support - TRF415
49417 M-03R Chassis Kit - M03
49418 TA05-R Chassis Kit - TA05
49419 TRF415MSXX
49420 Body Set Suzuki Swift - Lightweight
49421 Medium Narrow Dish Wheels - Fluorescent Yellow/0 Degrees
49422 Medium Narrow Dish Wheels - Fluorescent Pink/+2 Degrees
49423 Fluorescent Orange Medium Narrow Wheels
49424 Medium Narrow Mesh Wheels - Blue Plated/+2 Degrees
49425 TA05 Aluminum Differential Joint Blue
49426 TRF415 Alum Diff Joint - Blue
49427 TA05 Battery Plate Set (Blue)
49428 TA05 Center Plate Blue
49429 TRF415MSXX Upper Deck (Blue)
49430 TRF415MSXX Lower Deck (Blue)
49431 DF03 Setting Spring White
49432 DF03 Propeller Shaft - Blue
49433 DF03 Gearbox Plate Blue
49434 DF03 Gear Cover - Smoke
49435 DF03 Damper Cylinder Blue DF-03
49436 TRF415MSXX Lower Deck Set - For Stick Type Battery
49437 1/16 Panther G Grille Set - Photo Etched Grille
49438 Body Set NISMO R34 - Lightweight
49439 Body Set NISMO Silvia - Lightweight Coppermix
49440 TA05 Aluminum Center Plate (Blue)
49441 Aluminum Front Upright Blue M03 M04 FF02
49442 Aluminum Rear Upright Blue M03 M04
49443 M03R Alum Servo Mount - Blue
49444 M03 Aluminum Heat Sink Blue
49445 AM Crystal Set for Expec (01)
49446 AM Crystal Set for Expec (02)
49447 AM Crystal Set for Expec (03)
49448 AM Crystal Set for Expec (04)
49449 AM Crystal Set for Expec (05)
49450 AM Crystal Set for Expec (06)
49451 AM Crystal Set for Expec (07)
49452 AM Crystal Set for Expec (08)
49453 AM Crystal Set for Expec (09)
49454 AM Crystal Set for Expec (10)
49455 AM Crystal Set for Expec (11)
49456 AM Crystal Set for Expec (12)
49457 Toyota Hilux 4x4 Pick Up Body Parts Set
49458 TB02 Drift Spec Chassis Kit
49459 Lunch Box Gold Edition
49460 RTR TNX 5.2R Gold Ed. - TGM04 4x4 Custom Monster Truck
49461 M-Chassis 11-Spoke Wheels - 4pcs Black
49462 TA05 Urethane Bumper Black - Ltd
49463 TRF415 Urethane Bumper - Ltd Black
49464 GB01 Setting Spring Set - White
49465 TT Setting Spring Set - White/Short
49466 M03 Blue Plated Frame Set
49467 M-Chassis 11-Spoke Wheels - 4pcs Blue
49468 M-Chassis 11-Spoke Wheels - 4pcs Silver
49469 M-Chassis 11-Spoke Wheels - 4pcs Fluorescent Yellow
49470 M-Chassis 11-Spoke Wheels - 4pcs Fluorescent Orange
49471 TA05 One-Way Pulley 36T - Ltd Wide Pitch Black
49472 TA05 Diff Pulley 36T - Ltd Wide Pitch Black
49473 06 Module Pinion Gear (22T) - Ltd Hard Coated Aluminum
49474 3mm Countersunk Washer - Ltd 10pcs Blue
49475 DT-02 MS - DT02
49476 DF03 Gear Cover - Ltd Blue
49477 TA05 Body Mount Set - Ltd Blue
49478 TA05 Body Mount Set - Ltd Smoke
49479 TA05 Body Mount Set - Ltd Clear
49480 TRF415 Body Mount Set - Ltd Blue
49481 TRF415 Body Mount Set - Ltd Smoke
49482 TRF415 Body Mount Set - Ltd Clear
49483 Body Set Mini Cooper Racing - Ltd Lightweight
49484 Body Set Mazda RX-7 - Ltd Lightweight
49485 Body Set EBBRO 350R - Ltd Lightweight
Very Early Limited Edition Parts
49500 Not Used
49501 The Grasshopper II Super G
49502-49507 Not Used
49508 MacLaren MP4/5B Body Part
49509 Manta Ray QD Black Special Ltd Edition
49510 German Flakpanzer Gepard Kit
49511-49532 Not Used
49533 1/35 R/C Type-74 ???
49534 Fluorescent Colour Cable 7.2V Connector Set
49535 Fluorescent Silicon Wire
49536 Fluorescent Nylon Band Small Set (Yellow)
49537 Fluorescent Nylon Band Small Set (Orange)
49538 Fluorescent Nylon Band Small Set (Green)
49539 RD Fluorescent Green 70T Plastic Gear
49540 RD Fluorescent Pink 70T Plastic Gear Set
49541 RD Yellow 0.4 Spur Gear Set 94T, 104T
49542 RD Pink 0.4 Spur Gear
49543 TA01 Fluorescent Yellow Suspension Arm
49544 Tamiya Touring/Rally Car Fluorescent Green Suspension Arm
49545 Tamiya Fluorescent Green Adjuster Set
49546 Tamiya Fluorescent Pink Adjuster Set
49547 4WD Fluorescent Gear Case (Yellow)
49548 4WD Fluorescent Gear Case (Green)
49549 4WD Fluorescent Gear Case (Pink)
49550 Manta Ray TA01 Fluorescent Yellow Chassis
49551 Manta Ray TA01 Flourescent Orange Chassis
49552 Man Ray TA01 Flourescent Green Chassis
49553 Fluorescent High Torque Servo Saver Set (Yellow)
49554 Fluorescent High Torque Servo Saver Set (Green)
49555 4WD FF Touring Car Fluorescent Orange Damper Spring
49556 4WD FF Touring Car Fluorescent Green Damper Spring
49557 4WD Rally Car Flourescent Yellow Damper Spring
49558 4WD Rally Car Flourescent Pink Damper Spring
49559 4WD/FF Plated Mesh Wheels
49560 4WD/FF Plated Spoke Wheels
49561-49566 Not Used
49567 Acto-Power TRF Tuned Motor
49568-49572 Not Used
49573 TA02 Chassis White Suspension Arms (F & R).
49574 FWD Touring Car White Suspension Arms (F & R)
49575 Manta Ray White Suspension Arms (F & R)
49576 Castrol Celica Chrome Plated Wheel 4pc
49577 CVA Mini Shock Unit Set II White
49578 TA02 FF White Chassis
49579 TA02 FF Fluorescent chassis (Orange) (1 unit limited)
49580-49591 Not Used
49592 Sauber C12 `94 Tamiya All Japan Champion Special
4593-49594 Not Used
49595 RC Mini Cooper Plated Wheel
Rare Limited Edition Event Parts
92179 Mini Cooper Racing Union Jack Sticker
94003 RD Mesh Wheel Set Silver
94023 Mazda 787B Silver Wheel Set
94025 2WD Front Star-Dish Wheels (1 Pair) (Silver)
94027 6029 Rear Star-Dish Wheels (1 Pair) (Silver)
94102 Alfa Romeo 155 Silver Spoke Wheels
94148 Opel Calibra Chrome Wheels
Limited Edition Parts (New 42xxx Part Number Series)
42101 RC Pit Bag L - w/3 Inner Boxes
42102 TRF Special Damper Set - Hard Black Coating
42103 TA05MS Chassis Kit
42104 TRF415 MSXX - Marc Rheinard Edition 2007
42105 TRF501X World Championship - World Championship Edition
42106 TRF416 Chassis Kit
source: TC.com .....
the end is nigh ....
chris_86
Re: Tamiya 49xxx Limited Edition Parts
Messagepar chris_86 » lun. 1 sept. 2008 09:47
Merci MAKi :top:
Si un modo pouvait coller ce sujet dans "références" :roll:
Merci!
Retourner vers « Châssis »
